RS2 front brake hardlines - stealer only?
  • Ducky
    • May 2006
    • 636
    Need a set of the hardlines for my RS2 front brakes, are these available from a stealership only or does anyone else sell them?
    thx
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    I made some once. It's very easy to do and costs a matter of pence.
    SS
    • S-Express
      • Nov 2006
      • 1133
      make your own, or even better, replace the whole lot with one braided line
      • madpugger
        • Sep 2007
        • 1901
        Yup, made mine out of copper.
        Le Mans 2012
        Nurburgring 700
        1995 S2 Avant
        • Kieron20V
          • Mar 2008
          • 1505
          Or if you dont have or dont want to buy the tools do flare the ends, just take the old one off and take it to any local garage, ie not a dealership. They will make it for you for a couple of quid. I did this when I had to replace a length on my coupe, to the rear brakes. If i recall it was a fiver for just over a meter.
          1994 URS4 Avant RS2+
            i have some left over brake pipe from ym build up - if you get me a measurement i will make you some FOC
            • Ducky
              • May 2006
              • 636
              I was going the braided route, only to find the goodridge kit still needs the hardlines on the front....will make some enquiries on extending the goodridge lines to the caliper, otherwise I'll give you a shout Error404 on your generous offer.
              • S-Express
                • Nov 2006
                • 1133
                I found I could get custom lines made up for the same price as the goodridge kits and I didn't need hardlines.
                  The goodridge kit replaces the hardline to the calipers, your thinking of the hard lines that are further in the chain, leave these in, the main ones to change are the ones that go round the strut to the calipers
                  • Ducky
                    • May 2006
                    • 636
                    I thought this kit would replace the hard lines (to the caliper) also, but when you line up the parts there is no way to join the pipes together (male-male connectors needed).
                    So my brother and I came to the conclusion the kit only replaces the one rubber hose on the front from the caliper hardline to the inner body hardline, and the other 4 lines in the kit are for the rear calipers.... Although I can't access the rear of the car to see for myself..
                      That's because the connectors are on the car
                      • Ducky
                        • May 2006
                        • 636
                        If you're only replacing the single rubber hose on the front...I had expected the kit to replace the hard lines too. Obviously this is not the case so I'll have to replace those now (mine were knackered and can't be reused) or extend the braided hoses down to the calipers as mentioned in an earlier post.
                          There are two flexi lines on each side at the front - one from body to strut and one from strut to caliper
                          The male > male connection between the two flexi lines is the hardline around the strut.
                          If you get me a measurement of the length and i'll make you a pair
                          • Ducky
                            • May 2006
                            • 636
                            There is only one flexiline on my RS2, from body to strut...from there it's hardline to the caliper (one piece metal tube, no joins).
