Just put my car in for its MOT and its failed on the rear disk's being excessively worn. It went to a main dealers for the free MOT and i think they are being picky. Does anyone know the thickness if a new disk and the wear limit ie minimum thickness. Any help would be appriciated.
Rear brake disk
10mm thick, 8mm min.
On standard s2 rears.Carlos.
On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.uk -
It's £16.50 each. Brembo/OE/ATE/ECP discs, it's all a matter of preference. Over the years I've tried cheap and expensive cross drilled know brand and found nothing to choose between them as they do so little work so now I use cheap but look to change them sooner once they become rusty or grooved.
JohnComment
where have you got them from mate?never set your expectations to high that way you are never disapointedComment
they didn't say any thing about the rotted rear sub frame thennever set your expectations to high that way you are never disapointedComment
just bought some new discs (brembo) £22 a bit more expensive but they were local and i could only pick them up today. if it stops raining i'll be fitting them this afternoon
