caliper bolts
  • audiman
    • 4827
    Its not a stock bolt as its a big brake conversion, thats the point. The stock bolts are 10.9 IIRC. Its a precaution so that they dont fail when your doing high speed braking.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • diesel des
      • 3896
      The load on these bolts is shear while you are braking. The max force is as the wheel locks up. Doesent matter what size brakes you have, lock up and tyre friction is the limmit. Stock bolts torqued right will be 100%. Going to "stronger" bolts can bring other problems.... Thread lock in new stock bolts if your worried.
      • audiman
        • 4827
        you have missed the point here a bit. The thread was started as the person has low tensile bolts 8.8 fitted when AP brake setup was fitted, the stock bolts from audi (and they no longer fit with the brake upgrade) would have been 10.9.
        SO, the point here is that hes not upgrading his bolts, but making them same strength as original or stronger. NOT weaker.
        Audi UR Quattro
        • S-Express
          • Nov 2006
          • 1133
          the shear forces dont even get a look in - the clamping force means that the friction between caliper lug and bracket holds the whole lot together. The bolts' shearing properties would only come into play if the bolts were loose.....
          The higher the tensility of the bolts - the more clamping force and therefore higher frictional levels are obtained.
          I've rebuilt many a zetec - the cam pulleys do not have key ways, they rely purely on clamping pressure - never had a problem.....
          • epsilon93
            • Sep 2005
            • 5
            #20
            Is it advisable to use titanium bolts? They'll be lighter but I am not sure about strength and they resist corrosion.
