brake fluid
  • DEREKCO
    • Feb 2009
    • 435
    brake fluid
    HI to all I have changed the brake master cyl and bled the brakes off i have no leaks yet am loosing brake fluid nothing on the calipers or inside the car any ideas please
  • s2_bo
    • Oct 2005
    • 6067
    Is losing some through the clutch maybe?
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • Jenks
      • 261
      Does the clutch have a seperate resevoir?
      • s2_bo
        • Oct 2005
        • 6067
        Nope, it draws from the main one, there is a rubber pipe attached to the right side of the reservoir about half way down, that runs to the clutch cylinders.
        91 S2 coupé - RIP
        • DEREKCO
          • Feb 2009
          • 435
          no leaks on the ground gearbox is dry ,calipers are dry inside the car is dry
