Hi,
Just found a VW disc that may be of some use if you are looking for a 32mm thickness. The VW Passat W8 uses a 334x32mm disc with a 5x112pcd.
Part numbers: 3B7 615 301 & 3B7 615 302 A
Worth a look if you are running a 30mm because of no 32mm option, no idea on cost but one to consider...
Cheers,
David
Cheers,
David
