Another Bomb related question
  • Ski
    • 2591
    Hi All!
    Long time
    Everytime I press the brake pedal very hard, I get the warning come up. I can do a full journey braking normally and all is OK, its only on emergency stops, or, if stationaty and I press the pedal fast, warning also comes up.
    Bomb Test :
    Test states "This results in a 'dead' pedal which will feel rock hard with no servo assistance."
    The padel is hard (can only press it down 10%) and does not press down at all form the 1st pump (tried upto 30 pumps and same result). When engine is on, it allows me to press it half way down, and then slowly allows for the other half, while I feel a vibration through the pedal.
    Whats the verdict? Bomb? PAS ?
    ABY Coupe
  • Rusty
    • 18953
    Sounds like the bomb is emptying if you're feeling a vibration through the pedal. It will do this after the bomb test, needs to re-pressureise. Mine also did this due to the servo playing up, not done it for a while.
    • Ski
      • 2591
      How does one repressurise the bomb?
      ABY Coupe
      • Rusty
        • 18953
        Buy a new one
        It leaks pressure and then the pump has to re-pressurise it, this normall happens quickly but a lealking or tired bomb will not do so and thus never fully recharges, this is why the pedal modulates, the assistance isn't constant.
        • Ski
          • 2591
          Any ideas where to get a new one from? I fear its no longer sold
          Also, how much of a pain is it to replace so I can judge weather to take my chances with a second hand one.
          ABY Coupe
          • Rusty
            • 18953
            It's not too bad to replace on an ABY RHD, can't comment on other cars. I got mine from Belgium, can't remember the place now, was ÂŁ125 delivered.
            • Nuvo
              • Nov 2003
              • 3825
              Custom Autocraft
              Bomb
              • Ski
                • 2591
                Thank you gentlemen. Much cheaper than I imagined. All I need now is my VIN number and ready to order.
                For those of you who have replaced the Bomb, did you need to replace any other parts in that region? Would be a shame to have it all working for a week and a pipe bursts etc..
                ABY Coupe
                • Rusty
                  • 18953
                  Common sense required I think. All the pipes on mine seemed OK, no problems 2 years later.
                  • s2_bo
                    • Oct 2005
                    • 6067
                    They also do nice oil caps.
                    91 S2 coupé - RIP
                    98 S8 - Luxury barge
