yes but I think at MOT the light has to be active when you turn on the ignition and when you start it turn of the light.
ABS cancel on ABY
This is a sticky topic.
Originally posted by S2_avant 19930325 View Postyes but I think at MOT the light has to be active when you turn on the ignition and when you start it turn of the light.
Originally posted by larsaskogstad View Post
That was what I was thinking. Heard someone made some delayed light or something when you start the car or igntion or something and it takes 5 seconds then light turns off a bit sneaky.
- 1 like
That solution is good .. do you remember how you they did it ?
Its a tiny relay which turns it off after some secs.
Originally posted by simons2 View PostIsn’t yours a 3b ? Doesn’t it have an ABS cancel button ?
