Alloy brake calliper refubishment Q's
  • K Simmonds
    • Dec 2007
    • 7627
    I want to refurbish my Alcon callipers. There's no serious corrosion, in fact considering their 15 years old I'm impressed by how little they've deteriorated.
    So I've got a couple of questions.
    What's the best bet for removing the old paint, media blasting or acid dipping?
    Can anyone recommend somewhere re the above question?
    What's best for refinishing them? I want them in black.
    Where the hell do I start looking for new seals and pads?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
  • Flat on my back
    • Jan 2007
    • 2449
    I would recommend you try the products of GT500.
    Carlos.
    • ericd
      • Nov 2003
      • 1240
      you'll get a seal kit from Trident racing supplies Silverstone , around £80 , as far as pads go , double chcek the sticker on the caliper it'll state which depth of pad/disc was for that caliper, you've btype caliper so will probably be 330mm disc/ 16mm pad combo, for ds2500 compound you're want p/no: FRP1077H, I think i posted a few places over the years where i got them , last time around £120 delivred shop around , but that's part no, there's a plethora of pad option and prices if you wanna try and get the alcon original setup, just remember the pad depth you need (16mm or whatever), cause there were 4 different depth available on the btype
      • K Simmonds
        • Dec 2007
        • 7627
        Eric, thank you. That's exactly the sort of info I'm after.
        Yes my discs are currently 330mm, once their worn out I want to look into revising the set up slightly to allow me to run 16" wheels should I want to.
        1994 MTM RS2.
        2000 B5 TQS.
        • ericd
          • Nov 2003
          • 1240
          Hmmm, are you sure the caliper and bracket etc will fit under 16"
          • K Simmonds
            • Dec 2007
            • 7627
            No they won't at the moment, but I can just about bolt up a 16" 3B wheel with a 10mm wheel spacer. However the calliper is 'just' in contact with inside of the rim, obviously this not in anyway satisfactory. I'm yet to look into what disc's are available for the bells but I reckon if went for something around 318/20mm and got new brackets machined to position the calliper to suit then there'd be 2/3 mm of clearance without a spacer. I'll work it out properly when my current discs are worn out, may not be feasible but I'm fairly hopeful.
            1994 MTM RS2.
            2000 B5 TQS.
            • Kieron20V
              • Mar 2008
              • 1505
              I've been searching for replacement discs for mine today.
              Came accross this spreadsheet. Its a Czech site but all the info is pretty easy to figure out.
              Second tab btw.
              The part number for the discs im after is DIV2135, according to the spreadsheet they're available in 300-335mm, but I would imagine they would have to be specially made.
              I bet if you loose/machine down the spacers between the calipers and find suitably smaller diameter discs, you could fit them under 16s.
              I will be getting hold of Trident this week regarding new discs, so I can give you a heads up on the price of those should you choose to keep them the same size. Be warned though, Previous bill is over £550! in 2007.
              Kieron.
              1994 URS4 Avant RS2+
              • K Simmonds
                • Dec 2007
                • 7627
                Thanks for the info, I was expecting the disc's to be ridiculously expensive. Mine have got at least another set of pads worth of life left on them but the pads (as can be seen in the photos) are shot.
                I'll be interested to hear how much your end up costing as that will at least give me an idea.
                1994 MTM RS2.
                2000 B5 TQS.
                • Smith_S2
                  • Feb 2007
                  • 634
                  I'll Second that GT500 did a fantastic job of my rear brakes £160 inc new pad retainers, bolts, seals, paint, bleed nipples and postage. Worth every penny!
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    That's bloody good value, thanks for the heads up.
                    1994 MTM RS2.
                    2000 B5 TQS.
                    • Kieron20V
                      • Mar 2008
                      • 1505
                      Trident got back to me today with prices for the discs.
                      £249.84 Each plus vat. 3-4 weeks delivery time as they have to be manufactured.
                      Meh.
                      Just curious Kieran, do you know how long your discs have lasted? Seems my last set have only done ~20k miles. Not good.
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        That's a lot of money for discs, oh well.
                        Mine have aprox .75mm of wear each side, no idea how long they've been on there but I suspect it's been a lot longer than 20K. I guess it depends a lot on how aggressive your pads are.
                        I'm getting my set up reworked to 320mm soon to allow me to run 16"'s again.
                        1994 MTM RS2.
                        2000 B5 TQS.
