Clearance question
  • xgordyx
    • Sep 2006
    • 379
    Clearance question
    Does any one know how much clearance there is between the propshaft rear diff flange and the floor of the car.
    You might be wondering why i'm asking this in the brake section.
    What i'd thought about doing was possibily mounting a brake disk on the propshaft flange and make a bracket to mount a spot calliper, to use as the handbrake.
    I'm not sure if this is doable as i'm not sure of clearance and i cant look at my car as i'm at work in west africa
    Could just clamp the prop shaft is a pair of shoes, like a drum brake.
    • terrybullwon
      • Mar 2006
      • 8782
      What About a inboard caliper mounted on a drive shaft flange from the diff?
      Chef
      • xgordyx
        • Sep 2006
        • 379
        I've thought about this also and i think it is very doable.
        I like the idea of a single disk at the diff as it's maybe cheeper and i think making a hand brake cable to suit would be quite straight forward.
        • terrybullwon
          • Mar 2006
          • 8782
          There is a space frame sq using inboard brakes I will see if I can find the pictures
          Chef
            Only need a little disc in there, something off the back of a golf perhaps, 200mm or so and solid, could have it machined to minimum size and perhaps even lightened. Use a Golf rear calliper off a VR6 and suitable cable. Nice.
            • goodall
              • Jul 2008
              • 810
              good idea however will you not need to lock the diff at same time so that if one wheel where a lose/slippy surface both wheels are locked? otherwise rules a open diff will apply... however this good idea, a light steel disc about 8mm would be all you'd need which could bolt on between a the cv and input shaft
              • xgordyx
                • Sep 2006
                • 379
                Just doing this more for MOT purposes
                • andyg plym
                  • Nov 2006
                  • 4646
                  gordy.....im going back to a red aby coupe....
                  • xgordyx
                    • Sep 2006
                    • 379
                    Hay Andy.
                    Sorry forgot to reply to your PM, got distracted and forgot about it
                    I'll drop you a PM, probably tomorrow evening, should be doing work at the moment
                    • xgordyx
                      • Sep 2006
                      • 379
                      Did you manage to find a picture of this
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Its pretty serious
                        Chef
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Chef
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Chef
                            • Keeper of The Kitten
                              • Dec 2003
                              • 2317
                              I could be piddling in the wind here, but I'm fairly sure that a propshaft mounted brake for a handbrake isn't legal?
                              Martin Cutting
