Brake fluid motul rbf 600 any one using it?
  • terrybullwon
    • Mar 2006
    • 8782
    As per the title is any one using this fluid? I need something pretty serious but plan on changing a few things in the brake department so don't want to spend £30+ a lt for testing!
    Cheers James
    Chef
  • driftin jo
    • Sep 2007
    • 2222
    I can recommend it , it made a big difference .
    Before using it when I got some serious heat into the brakes they went spongy as the fluid started to boil.
    I haven't had that at all since using it.
    • Ducky
      • May 2006
      • 636
      Use Castrol SRF myself, always thought that was a good fluid.
        Only good for a year though,
          should bleed your brakes out every year anyway Jamo
            2 years if you use good fluid on a street car as per the Audi guide
            Castrol is good stuff but on a street car it's overkill and has to be replaced twice as often
            • lind4hl
              • Jul 2008
              • 2465
              1 year i would recommend...
                on topic for Chef, http://www.s2forum.com/forum/showpos...9&postcount=18
                  Again not necessary, only required on the performance fluids where the hygroscopic properties of it mean that has to be changed that often.
                  • lind4hl
                    • Jul 2008
                    • 2465
                    Originally posted by Jamo
                    Again not necessary, only required on the performance fluids where the hydrospcofic properties of it mean that has to be changed that often.
                    All brake fluid will get Water (moisture) in it..
                      Yes I know, some are more hydrospocific than others how ever therefore absorb more water quickly and need replacing sooner such as the castrol!!!!!!
                        Yes I know, some are more hygroscopic than others how ever therefore absorb more water quickly and need replacing sooner such as the castrol
                        read what i'm posting carefully
                        • lind4hl
                          • Jul 2008
                          • 2465
                          Yes the brakes works for sure, but lets face it:
                          The brakes are the most important thing in your car for safety in your own life ( and maybe others)!
                          For an normal mechanic with axle stands etc it is maximum 1H work on a car.
                          1h work that may save you 60 years?
                          i aint cheating...
                            I always notice a big improvement in the brakes after replacing just normal DOT5.1 fluid after 12mths
