Calliper Question
  • S2 Ant
    • 3682
    Calliper Question
    http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
    Are these the correct callipers to fit the S2?
    What size discs can be fit with them?
    Thanks
    Ant
    2011 Kawasaki Z1000
  • Sidspud
    • 1223
    I nicked this from the 996 Caliper thread. It was originally posted by Corey....
    A quick guide to calipers and there applications
    Boxster front (2.5/2.7) will suit a disc 25mm thick
    Boxster S will suit a disc 28 - 30mm thick (if a 30mm disc is used you will need to machine the guide pins by 1mm)
    Boxster S exactly the same as the front normal Boxster (but in red)
    They would work if you got the correct disks (A8?) and brackets.
    The text states that they are monoblock. Its hard to see from the pics, but I have my doubts.
    ex '93 Avant owner
    • S2 Ant
      • 3682
      Should be fine, i can ask them exactly which model they are to confirm, but they look like they will be a bargain. just wanted to confirm they were correct from the description, but too lazy to go look.
      Ant
      2011 Kawasaki Z1000
