Just making sure I get the right ones ....trying to find anything with 993 calipers is a PITA as they are not listed as that model and usually come under 911 or C4 model
Will Pagid U1204 Pads fit my 993 calipers?
Tags: None
Depends which 993 calipers you have! (sorry) You might want to check out Motorsport World - if you shop by brand (left hand menu), select Pagid, and then your Porsche 911/993 model, the Pagid part numbers (U1204, E1234, etc) and a picture of the pads will pop up when you hover over one of the list entries. For the record, I have no connection to them, blah blah, etc.Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
