Amurican Brake Porn...
  • urs4guy
    • Dec 2007
    • 192
    Hey Guys
    Hap Maguire here from the mountains of Colorado. I've been a lister for a while but have never really posted very much. These are some pics of my 93 urS4 that I've owned since new. This is the 3rd set of brakes I've put on this car and I can report that the results are stunning both visually and from the driver's seat. The fronts are Cayenne 6 piston calipers with 2 piece 355x32 rotors with custom hats. The brackets are one-offs from Apikol but they do have the specs to make more. The rears are 993tt calipers with 2 piece 314x30 rotors with custom hats and brackets. The parking brake is actuated by a WRC style parking brake/master cylinder that is plumbed into the brake system. The car itself is even better. Enjoy the pics.
    Hap, wit dakine Big Brakes not from Evahboost, Maguire
  • M_GORDON
    • Oct 2008
    • 1295
    • Home: Isle of Man Current: Vatican City State
    WOW
    Fine fine!!
    photobucket SUCKS
    • AndersS2
      • 1364
      • Home: Norway
      Great upgrade you've done there.
      Also liking the "m3" exhaust style
      Did you check the total wight of the oem brake system vs the new brake system?
      Can you put some in more info on that wrc style parking brake system (how it works).
      Anders - S2 Avant Clubsport - 8pots or die!
      • urs4guy
        • Dec 2007
        • 192
        Originally posted by M_GORDON
        WOW
        Fine fine!!
        Hey thanks. It does the primary job of pulling down the speed of the Big Beast quite well but it also looks very nice both stationary and rolling down da road.
        Hap, wit dakine braking thanks not from Evahboost, Maguire
        • urs4guy
          • Dec 2007
          • 192
          The sound of the exhaust is pretty loud but oh so soulful. The big cams make it idle at about 1400 rpm and it still has a lope to it. Sounds like one of my younger years Big Block Chevys.
          Weight savings was not the primary rationale for this upgrade. Had it been so I would have stayed with the front 993tt calipers and 322mm 2 piece rotors. Given their size, the 6 pots still weigh less than the G60s they replaced. I am a believer in balanced braking. I've had the rear brakes mounted for about 8 years and this is the 2nd generation of parking brake application. The first was a dedicated master cylinder that was mounted near the rear axle and activated by the stock parking brake handle and cables. This used hydraulic activation to set the rear brakes. The second is a much cleaner solution. We're using a K Sport Hydraulic Handbrake that can be found here:
          Ksport hydraulic handbrake assemblies are made for drift and rally use. Browse the hydraulic handbrakes in the range and compare options.
          It also uses hydraulic activation to set the rear calipers but its all contained at the parking brake handle assembly. Its plumbed into the line running to the rear brakes. Here's a picture in my car.
          Hap, wit dakine Big Rear Brakes not from Evahboost, Maguire
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            Hey,Hap.It's pop here too.Nice to see you around guys!!.will let ya know when i completed my brake conversion.
            one of a few I5 from Asia.
            • Le S2 Audi
              • Jul 2009
              • 3805
              Brake porn...
              New S2 - S8 & RS2 -RS6 Keyrings
              • urs4guy
                • Dec 2007
                • 192
                Hey Pop. Good to see you get around. I'll be happy to see your brake conversion when it gets done. Are you ever gonna visit the USA?
                • popdemonic
                  • Dec 2007
                  • 1304
                  • Country: Thailand
                  Next week,it'll be my long weekend.I'm going catch the flight to Hongkong and China.
                  when I'm back,Hopefully,my brake conversion will begin.Now I'm going to put the 2009 Cayenne Caliper on my car.They're Huge Calipers.I'll meet up you when I go to USA Hap.We're just da Green addicted.:mischeif:
                  • PeteUr
                    • Jan 2010
                    • 331
                    • Country: Togo
                    Very nice, really like the brakes and the system, what make are the back boxes, look like magnaflow to me - 3 inch inward to 2.5 twin outlet
                    what wheels you got for the car
                    Sapphire cos running custom 2.8litre conversion,es cos rims,raven black leather interior and 500+ with the gas turned off.
                    Audi s2 cooking on gas
                    • lind4hl
                      • Jul 2008
                      • 2465
                      word, got the same on mine, awesome boxes...
                      • PeteUr
                        • Jan 2010
                        • 331
                        • Country: Togo
                        Yeah I had one recently for the urq but i'm changing it for a 3inch in and out as it will be easier for making the system
                        • urs4guy
                          • Dec 2007
                          • 192
                          Thank you sir. Magnaflow they are but they're 3" inward and 3" twin outlet. With the 3.5" piping from the turbo back, its pretty loud. Good thing I have a great audio system and lousy hearing.
                          Those are Kosei K3s in 18x8.5 et 35 with 255/35-18s. They're hand polished as well. I also have a set of SSR Comps in 18x9 for the track.
                          • urs4guy
                            • Dec 2007
                            • 192
                            Any plans on when you might visit the USA?
                            • 91gl
                              • Feb 2010
                              • 4
                              • Home: Greece Current: United States
                              Hey Hap, sent you the tracking numbers over on audizine. your car is gorgeous man, good luck with it and the new wheels
