S2forum brake performance¡¡ 100km/h to stop
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    hello friends
    yesterday i was testing some of my current brake performance,with a friend in my car and with more or less 1/2 of fuel tank...
    i,ve done some diferent diferent tests and i am very sorprised and congratulated with the results.
    i did it in a closed roads of course
    i never used the 100% of the brake pedal,always around 85% as much.
    my friend and me we think that my cars can stop 100km/h to complete STOP in around +/- 10 meters¡¡ that sounds fine
    surelly i will can do it better if someday get scared with something dangerous in the road...braking 100% full pedal.
    of course the road was dry and in very nice condition.
    mine did it with Audi Ceramic 6 piston calipers,with special custom porsche pads, 385x36 perforated discs, Girling DOT 4 +, braided brake lines, and Goodyear F1 asimmetric tires with 235/35/19
    after this... it would be nice if we can compare our diferent brake setups and diferent perfonmance true?? talking about brake distance used in our cars and wiht wich conditions like car weight, road state,and brake setup,pads used,etc....
    what do you think about it??
    come on partners we have to share this type of info too.
    -Tomas-
    14
    less than 10 meters
    7.14%
    1
    10-15 meters
    7.14%
    1
    15-20 meters
    14.29%
    2
    more than 20 meters
    71.43%
    10
  • s2driveruk
    • 12696
    thats pretty special performance!!!!
    1992 3b S2 Coupe
    • nervas
      • 357
      • Country: Lithuania
      What was time taken to stop from 100 to 0 in seconds?
      Xtra Racing
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        not sure 100%, i did not measured it,but i can say you that very very few time since my foot it is braking in the pedal....
        other day i will try to measure it with a friend ( more or less)
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          come on vote in the pull ,go to a closed road today and do it
          • nervas
            • 357
            here is F1 spec on braking:
            Xtra Racing
            • s2driveruk
              • 12696
              i would but she's flying currently.....up on 4 axle stands with no wheels on and no radiator/breather circuit/intake plumbing
              Once the new boots are scrubbed in and ds2500/discs bedded I will for sure
              1992 3b S2 Coupe
              • nervas
                • 357
                I think that 30 m +/- 5 would be more realistic
                Xtra Racing
                • gedu
                  • Feb 2007
                  • 295
                  I'd say around 40m (+-5m) is realworld braking performance from 100km/h (true speed) not taking reaction time into account. Results vary between tires, surface and ABS generation. Even new cars strugle with 40m on controlled surfaces sometimes. Tires make a huge difference, R-compound street tires could start approaching 30m with good surface and skilled braking.
                  Most of times even stock brakes are enough for ABS to come into action on dry, dust free surface, bigger brakes just make it repeatable
                  All quattro products have been dermatologically tested, and are safe for daily use.
                  • nervas
                    • 357
                    100 to 0 in less then 10 sec you will make only if you hit the wall
                    Xtra Racing
                    • Evilgoat76
                      • Feb 2010
                      • 278
                      • Home: Canada Current: United Kingdom
                      Which is EXACTLY what the missus did with the suzuki. Poor wall
                      Not done the S2 but...
                      Suzuki cant attain 100KM/H without a headwind. Stopping distance I really dotn want to think about without the wall.
                      100, probobly in the higher bracket, it doesnt do anything fast.
                      • Rocco
                        • Aug 2007
                        • 6393
                        • Country: Spain
                        you would like to say 10meters not seconds true?
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          i will do more test... if i can this weekend i will do it with a real meters measure... :mischeif:
                          i bet 1€ that i can stop my car from 100km/h to STOP in less than 30meters,measuring the speed with a GPS.
                          ah¡¡ i am talking about the distance spent since my foot it is working on pedal not counting reaction time or something similar
                          • nervas
                            • 357
                            right, mistake.
                            Xtra Racing
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              right, mistake.
                              small mini test this mourning coming from the work
                              with daylight¡¡ ,because yesterday the tests with my friend were in the dark night under the monnlight
                              15-20meters are Ok.
                              stop the car in 30 meters are too easy now coming to 100km/h.
                              10 meters only in my wet dreams , i will have to check all fine fine with a proper measure the next weekend
                              it brakes like a Russian mountain ¡¡ surelly it is not good for the chasis...
