Cayenne Calipers: Is there a definitive C4 solution?
    I did a search yesterday but I didn't find a definitive answer for a complete bolt on using OE parts. What I do understand (maybe) is:
    1. If you have a C4 UrS(6?) with HP2 calipers already, the Cayenne calipers will bolt onto the hub carriers.
    2. Toureg 350 mm x 34 (??)mm rotors are 5 x 112 and work without modification?
    3. You need 17" wheels minimum.
    Please correct/enlighten me on any or all of the above.
  • 2226
    • Mar 2008
    • 52
    • Country: South Africa
    Hi Dave
    See if any of the links in this thread is of any help -
    Does the caliper bolt directly to the hub assembly on Both 2004 and 2008 R32s?
    friggin quattro crazy
      Originally posted by 2226
      Hi Dave See if any of the links in this thread is of any help -
      http://forums.vwvortex.com/zerothread?id=4437894
      Thanks. I did gain a *little* info, especially the bits about Mercedes rotors. HOWEVER, I need Merlin'sS4 to dig into his memory banks and tell me exactly what parts he used and how he did it.
      Paging Merlin'sS4, please pick up the White courtesy phone.
      • popdemonic
        • Dec 2007
        • 1304
        • Country: Thailand
        Cayenne Caliper has 130mm mounted distance
        HP2 Caliper has 132mm mounted distance.
        you may use the 2005 A8 V8 FSI Rotor discs(360X34mm).
        overalls dimension is exactly the same as stock 314X30mm discs.
        in this case(my route),you will need the extra bracket for the bigger rotor discs.
        IIRC,Tris(MerlinS4) is running on 330mm disc from later model of Merc E-class with little
        machining job.I guess he must be using the Caliper from the Cayenne V6 engine not from V8.
        the V6 caliper has shorter on the mounting legs(For 330X32mm Discs),The V8(For 350X34mm Discs).
        one of a few I5 from Asia.
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          Tris has been done this job by Corey. The guys who already disappeared from the forums !!??
