Crazy Rattling
  • Crazy Rattling
    hi guys,
    I have only got a 7a coupe at the moment, still waiting for the finances to buy an s2.
    the problem i have is a really loud and really annoying rattle from the back brake area, it stops when braking so must be something to do with the caliper?
    I replaced the caliper carrier as i though the guide pins were worn and this fixed the problem for a couple of weeks but now it is back with avengence
    the calliper does move around a bit when parked without handbrake, not sure if this is normal or not
    thanks in advance
    Phil
    doesnt sound it...sure you havent got a sheared bolt on the carrier or something?
    1992 3b S2 Coupe
      they seemed ok when i changed the carriers, i'll have a look to see if they have come loose though
