As per the title, my servo has had sticky seals for a few k now and I'd like to sort it out. If anyone knows of a place that can refurbish the OE servo then please let me know, a new one from VAG is a no-go due to the price!
Or, does anyone know whether the servo is available as a standard part from the OE supplier, can't remember exactly but I think it's ATE.
im so glad my problem wasnt the brake servo in the end, but a leaking hose. My RS2 servo is specified at a cost nearly £700 so i wouldnt want to even think about it...
Hi Rusty, when you say sticky seals, what exactly do you mean? I have assistance when braking then a sudden press of the pedal again & its gone? Also have a pulsating pedal like the ABS pump is running. Had 2 wheel bearings replaced but only 1 sensor was removed from the hub, i disconnected the rear under the rear bench. Should have been going to Chatsworth House to the Rally day tomorrow but now i'm messing with "lumpy" brakes! Is there an easy way of checking the gaps of the ABS sensors, should i be checking there resistance readings with a multimeter also? Any advice much appreciated as my patience is dwindling with the S2!!
