How much brake fluid?
    How much brake fluid is required for a complete change and flush?
    2 or 3 litres?
    Does anyone know if GSF or ECP stock ATE Super Blue / Motul RBF 600?
    Scrap the GSF question they stock it but how much is required?
    • s2driveruk
      • 12696
      1.5-2ltrs for a good flush then you can pull 250ml min through each caliper....oh and make sure you do the clutch line too for completeness
      1992 3b S2 Coupe
      • s2driveruk
        • 12696
        and bleed inner and outer nipples on the brembos together ideally
        1992 3b S2 Coupe
        • EspenW
          • Apr 2007
          • 1534
          • Country: Norway
          I use approx. 2.5 liters. 500cc from each caliper and some from the clutch. I usually flush a little more than 500cc form the first caliper, since the old fluid from the master cylinder (the remaining fluid that can't be sucked out) will come out of the first caliper.
          This is way more than the fluid content of the system, but it is a good idea to use extra fluid in order to flush the system properly.
          I often buy a 5 litre bottle and do two cars at once, cost per liter much lower.
          1994 80E Avant
          1986 2L Golf 2 on Alcohol
          • Fat Audi 80
            • 10547
            I need to flush my clutch. Anyone offer some advice on doing this lying on you back with car on axle stands???
            Thanks, sorry for minor hijack Jamo.
            The Perfectionist
            • GazzaG60
              • 4133
              dont lie on your back
              get a motive products bleeder. steering to 1 side, linkage loose.
              get a 1/4 drive, extension and skinny matching socket.
              lean over and fill your boots. its an easy job then
              • s2driveruk
                • 12696
                Steve - its a sod of a job to do on the 3b...though with no battery try and a bit more space on the right side on the aby you should be able to get to it from about i would expect?
                If you do have to go down under, then not much i can say than have a good feel about to trace the line into the slave, locate the 13mm num with the rubber cap on it, prise it off with fingers, get a long piece of tubing and using an ezibleed or whatever method, make sure you draw through plenty of fluid. Its likely to get a bit messy down there as you are working purely on feel rather than being able to see it so make sure you can open the bleeder enough for fluid to flow but not enough that you have to faff with nipping it up again
                I have this to do on mine shortly....the joy
                1992 3b S2 Coupe
                • Fat Audi 80
                  • 10547
                  Thanks Chaps.
                  I have an easi bleed and good socket set and tools etc, so it sounds doable!
                  I will report back if I am successful...
                  The Perfectionist
                  • s2driveruk
                    • 12696
                    dont do your back in again doing it
                    1992 3b S2 Coupe
                      The official manual also states 500cc per corner - and another 500cc first of all from the master cylinder if fitted with a bleed valve - never seen that on S2/RS2 master before.
                      The clutch is a booger - I really should do mine too.
