Longitudinal Acceleration Sensor
  • montez
    • May 2010
    • 396
    Whilst removing my interior of my new car for a clean, I came across the LONGITUDINAL ACCELERATION Sensor under the rear seats. For some reason this sensor has been disconnected, is there likely to be any reason for this? I know it has something to do with the ABS and worry that if I re - connect it, it may kill my brakes!!
    BTW part number is BOSCH 0 265 005 007
    Cheers!
    1991 Audi S2 Coupe
  • Phil Payne
    • Jul 2009
    • 328
    Cheers!
    Can't see why. The Sport quattro always had one, but mounted transversely.
    The ur-quattro got one at chassis 85-H-900252 (early 1987) and most if not all Audis have had them ever since.
    It solves a problem that was more prevalent on the Ford Granada - it is JUST and only just possible to tap the brakes on a really slippy road (wet ice) and lock all four wheels simultaneously. Since the ABS doesn't see a wheel rotating, it thinks you've stopped. After my manager put his 2.9 Ghia into a hedge near Newmarket I went for a play in Wellingborough Swimming Pool carpet - out of about twenty attempts I got no ABS on two.
    It's only a mercury switch, just to generate pulses if the car's still moving.
    • montez
      • May 2010
      • 396
      cheers for the quick reply. I have re fitted it and the brakes seem fine!
      1991 Audi S2 Coupe
      • HPmuirt
        S2Forum April Fool
        • Apr 2005
        • 3014
        Would the movement sensor actually detect locking the wheels on ice?
        Cheers n
        Si
        Subtle mods here and there
        2011 A5 3.0 TDi - Lava Grey
        • Phil Payne
          • Jul 2009
          • 328
          As always, a few German PhDs had their hands in designing it ...
          It detects anything that seems like movement and tests for vehicle movement by unlocking one wheel.
          I always wonder what the poor things make of dogging.
            Funny... I thought that G-sensor was deleted circa 1992/1993 on the S2 at the same time they removed the ABS cancel button... or maybe they simply built the G-sensor inside the new ABS controller - never had one open for a sneak peek.
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              The same as the rest of us I suspect.....a morbid fascination with why the hell anyone would want to do it
              Cheers n weirds
              Si
