No ABS Light
    Here's what I suggest first...
    1 - check you get 12V when brake pressed (key ON) at ABS Controller on pin #25
    2 - check you have good 0V / earth at ABS controller on pins 10, 20 & 34
    3 - check fuse 29 - 10A is ok
    4 - check fuse 12 - 15A is ok
    5 - Verify the bulb works (and cluster wiring) by disconnecting the BLUE multi-pin plugs at the auxiliary relay panel and then locating the red/yellow wire on the loom of the blue plug that connects up to the cluster. With the ignition on, the ABS lamp should come on when you connect this red/yellow wire to earth. Look at track 36.
    If the bulb works then you need to ascertain if you have connectivity from that red/yellow wire onto pin #29 of the ABS controller... You can do that by reconnecting the BLUE multipin plugs and disconnecting the big connector at the ABS module... then connect pin #29 to 0V and see if the lamp comes on.
    I assume you know how to map the notation such as T10a onto the coloured plugs in the fusebox - without that knowledge you are going to be a LONG time.
    • montez
      • May 2010
      • 396
      I spoke to a friend how has a 1992 V6 Coupe, he had the same problem and replaced the ABS Combi Relay under the rear seat (number 349) this had a 10a fuse and looks the same as the ABS Relay under the dash.
      When you say mapping the notation, what do you mean?
      BTW thanks for all your help!!!
      1991 Audi S2 Coupe
        I mean when the schematics say connector T10a - do you know which one that is ?
        • montez
          • May 2010
          • 396
          Yeah, I understand cheers. Will have a crack at it tomorrow!
          1991 Audi S2 Coupe
            #20
            Hint - the secret is on s2central.net - follow tech pages to wiring diagrams and seek out my primer document... Tis th culmination of uncountable number of hours on the subject. Even with factory info to hand it took a long time to summarise so much in that document. It's not something you could ever work out by looking at the schematic.
