I've been thinking about this too much of recent.....Has anybody on here ever carried out calculations behind the braking forces that different callipers / rotor diameters deliver. I've a few calculations done in excel based purely on piston size, average diameter of the rotor and pressure applied to produce a compartive chart showing braking torque applied to a standard s2 rim & tyre.
Assumptions:
1. With a 4 pot fixed caliper only the area of the pistons on one side are used when calculating brake force because the 2 pistons on the other side are only there to provide an equal and opposite reactive force.
2. Calcs based on one hub rather than one axle.
3. Figures here sofar don't take into account heat dissipation / cooling, Centre of Gravity, Upgrade required on the rear axle as a result of front axle upgrade, or many other factors for that matter.
4. The AP 6 pot with 360mm rotors shown here needs bigger wheels so i just wanted to put it in for comparative purposes.
5. Information is as accurate as I can get my hands on re piston sizes etc but I could be off so all pointers appreciated.
So
1. Any brake engineers / knowledgeable others that could throw an eye over whats here already and point me in the right direction.
2. Any guru's on excel to help me make a decent graph or tidy up the way the information is input to this sheet?
3. Has anybody got the Centre of Gravity location for a standard s2 Coupe, specifically an ABY with Air Con, not lowered.
4. Anybody got details of any other caliper that will sit nicely over the 314mm A8 rotor and also fit under the 16" avus rim that they'd like added.
5. To calculate the average braking diameter is it ok to use the halfway point between the max braking surface diameter and the min braking surface diameter or should I use a more complex method to calculate this?
Shane
