993 front calipers for my s2 3b
  • dich
    • Apr 2010
    • 52
    • Country: Bulgaria
    Can I fit 993 calipers for the front to my s2 and what i need.
  • denniselbows
    • 740
    the 993 twin turbo calipers are the big reds which use a 322mm disc. they just fit under avus rims but i think you need spacers for them to fit under the 5 spoke speedlines fitted to the 3b 5speed cars. a friends coupe has a movit kit under avus rims which is basicly the same brakes as mentioned but badjed as movit also the upgraded brakes for the rs2 was the same but i think the rs2 has 17" rims
    never set your expectations to high that way you are never disapointed
    • epic
      • 1317
      Yes you can. I have them on my car. You need custom bells for the disc and adapters for the caliper. They use a 322 disc and as denniselbows says fit under Avus 16 alloys just. I have a kit made by Movit.
      • denniselbows
        • 740
        I belive the clearance is only a couple mm or so. I wish I went for the movit kit instead of the mono blocks I did.
        • epic
          • 1317
          Clearance was tight but was never an issue. Although I've run 17 S4 alloys for a while.
          • epic
            • 1317
            Also the Movit kit was about £1500 when new but then I've had them on for almost 10 years
            • curlyks2
              • 1069
              I actually wish completely the opposite - that I'd gone for something (anything) other than the Mov'it kit! They've been nothing but hassle in the last couple of years. F***ing plate lift.
              Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
