Is the RS2 upgrade disc (322x32) a Porsche part?
  • autohausdolby
    • Aug 2009
    • 87
    As it says really - is the factory upgrade 322mm x 32mm RS2 disc a Porsche part, or is it Audi specific? I'm having difficulty tracking them down through my normal parts suppliers. I can get Zimmerman drilled 304x32 (stock RS2) discs no problem, but we're struggling with the 322.
    These are the numbers for the "upgrade" discs -
    8A0 615 283
    8A0 615 284
    If they are a Porsche part, does anybody have the Porsche numbers for them?
    Thanks
    Audi specific in that you can only buy the 2 part disc from Audi.
    There is a porsche disc from the 965 turbo that is the same but one piece.
    If you do a search this is extensively covered on the forum
    • Le S2 Audi
      • Jul 2009
      • 3805
      Just found this info...
      New S2 - S8 & RS2 -RS6 Keyrings
        Disc's 322mm
        993-351-425-10 (left)
        993-351-426-10 (right)
        Disc's 304mm
        993-351-421-00 (left)
        993-351-422-00 (right)
        http://www.s2forum.com/forum/showpos...2&postcount=15
        Those are wrong, the 993 disc is 2 piece and has the wrong hat height. You can use them only if you have a custom hat made as they are 5mm shallower than required for the RS2 caliper bracket.
        You need 96535104500 and 96535104600
        • Le S2 Audi
          • Jul 2009
          • 3805
          Realised that after posting it... I have updated the posting...
          • autohausdolby
            • Aug 2009
            • 87
            That's why I started another thread It's good to be sure you're reading the right information - it's expensive if you don't...
            Thanks for your help
