ABS braking system removal
  • terrybullwon
    • Mar 2006
    • 8782
    as per the title has any one removed this and the pressure acumulator and used a bigger master cylinder?
    Cheers James
    Chef
  • terrybullwon
    • Mar 2006
    • 8782
    Sorted, after a conversation with Repo pedal box on the way from Pro-mo Racing.
    Three master cylinders and now i can remove the problematic pressure acummlator and the whole abs system
    Chef
    • max_s2
      • Mar 2006
      • 498
      • Country: Latvia
      terrybullwon, and what has to be removed if I just want to remove ABS and keep everything else? Any pics you have from the cylinder etc?
      • terrybullwon
        • Mar 2006
        • 8782
        I have done it with a pedal box and twin master cylinders with a balance bar. Just removing the abs control is maybe a little silly.
        Chef
        • andy10v
          • 5996
          Could you remove the whole lot and retro fit vac assist brakes from an earlier car?
          Sold ABY-stock
            yup. I'm thinking about it. using pneumatic servo from a 100
            • andy10v
              • 5996
              Would you then use a single outlet pump rather than the split one? Or would you switch to an electric one?
              My 88 10v 90 had vac brakes if you are looking for other sources.
              Sold ABY-stock
              • K Simmonds
                • Dec 2007
                • 7637
                Hmmm, shall be watching this thread with great interest.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                • max_s2
                  • Mar 2006
                  • 498
                  • Country: Latvia
                  Yep, me too. Pictures wanted! Post up guys!
                  • mrtat2k9
                    • Jan 2009
                    • 659
                    dont know if its the same but i removed the abs of my 90 20valve with no problems could just do with some way of adjusting it from front to back. was just a case of puting new brake pipes on and removing loom and ecu along with abs unit. and not had any problems as of yet with it
                    • max_s2
                      • Mar 2006
                      • 498
                      • Country: Latvia
                      ABY engine ABS block schematicly is like this: master cylinder -> some strange reducer or smth like that (see attached picture) -> ABS block. Master cylinder has 2 outputs, one for front and second for rear. I dont know what does the thing between ABS block and master cylinder. However, ABS block has 2 inputs (rear/front) and 3 outputs (front left/front right/rear).
                      If I remove ABS block, what where must I connect? Does anybody know?
                      • lcsmith
                        • Jul 2007
                        • 477
                        Hi Terry,
                        I know this is an old thread but I'm looking at deleting the ABS and wondered what box you went for.........was it this one?
                        In fact if you could actually explain your entire setup that would be great!
                        Thanks,
                        Leigh
                        PS - Pics would be great
                        Audi A4 (B7) 2.0 Tdi (140PS)
                        Audi 80 (Typ 89) Quattro 16v
                        2 x Audi URS4 2.2 20v Turbo
                        Audi 100 (C3) Quattro 2.2 10v Turbo
                        Audi 100 (C3) 2.2 10v Turbo (Auto)
                        Audi 200 (C3) 2.1 10v Turbo - Scrapped
                        2 x Audi 80 (Typ 89) Quattro 1.8 8v - Scrapped
                          Terry?
                          • lcsmith
                            • Jul 2007
                            • 477
                            You know who I mean
                              I'm going to call him that via text and on facebook, made my evening
