Porsche 996 Caliper Refurb
  • Le S2 Audi
    • Jul 2009
    • 3805
    Originally posted by s2_wot
    Just a thought and I could be way off, is it not normal to trim down the 4 little pins that the pads sit on with these brakes, doesn't look like it's been done in the 1st pictures.
    Yes Shane, You are correct.
    You have to take at least 1mm off each side if you want to use the 323 discs....
    But I still think the issue is with the bracket not being correctly positioned to have the disc centered properly....
    I have not had any issue with my brakes using the Bambridge Brackets.... (other than me warping the disc's) - but thats another story...
    New S2 - S8 & RS2 -RS6 Keyrings
    • s2_wot
      • Aug 2006
      • 2178
      Quick rub of an angle grinder before they go back on to be safe.
      Shane
      • Dpicariello
        • Mar 2006
        • 621
        I took quite a bit off the pins when I first fitted them but I have now taken even more off so they definitely won't touch the disc. There's still plenty to hold the pads securely though.
        Rob, I work for AP Racing so there was plenty of advice there. They didn't take long but you need the right tools and make sure you soak the new seals in kluber fluid or similar conditioning fluid beforehand.
        Unfortunately this was a one off as normally we wouldn't rebuild a caliper that wasn't our own.
        I'll be fitting these tomorrow so will check to see how square everything is then.
