Hi
can anyone tell me what would the brake pump failure symptoms would be? ... Other than a head on collision due to brake failure!!
Since i replaced the brake bomb twice with the help and top notch service from Paul(custom autocraft), the brakes have improved very much and the feel is much improved, as well as the number of pedals with engine off till you reach the rock pedal.
However, im still getting that spongy feeling on and off as well as there is still some play on the pedal itself.
Brake shoes/discs are recently changed, i have braided pipes all over, new hose going from the pump to the bomb recently done(was leaking power steering fluid). No leaks anywhere else, no reduction in brake or PS fluids.Brakes have been bled to death.
The pump itself has never been touched and it is one of the long ones that some rs2s came with. Unfortunatelly i cannot see the part number.
Anyone can tell what else to look for? Anyone can source a brake pump cheap?
What does the brake pump master cylinder do? could that be the fault?
thanks
thanks
