Do you guys have any recommendations on which brake pads are best for the standard 304mm OEM disks? Ferodo DS2500 seem to be rated on this forum. Will they fit the standard size disk? I don't do any track driving at the moment, so it will be just for normal fast road use.
As I am going to do this job myself what other parts should I typically need when I am replacing the disks and pads? I have heard that typically the bolt that holds the disk in place also needs to be replaced.
Thanks in advance.
Thanks in advance.
