When the car is stationary and you press the brake pedal with the ignition on the system checks come back as OK. Then when I press the brake pedal hard it travels quite a way and the Brake System warning light comes on.
The car has been stood for a couple of years so the brake fluid isn't going to be that good so it will need changing anyway. The manual says to check the level which I'll do tomorrow morning. It also suggests the brake bomb but my experience of these on the UR is that the pedal goes hard when this is knackered as there is no servo assistance.
My main point is that I had the hydraulic line off to fit a new seal in the power steering pump, so is it possible that I've got air in here and if so how do you bleed it or is it self bleeding?
