Power steering hose removal
  • Power steering hose removal
    Is it possible to remove the main power steering hose that attaches to the rack, without removing the entire engine on a type 89?
    Main power steering hose from rack to pump ?
    undo at the pump, undo at the rack. remove from bracket next to dipstick and withdraw it
    Mike
    http://www.s2-audi.co.uk
      one of them attaches underneath the rotory valve housing, access will be tricky but should be doable
        I will take another look at this chaps...access is very restricted.It can't be any more difficult than some of the manifold bolts!
          i dunno, if you've got skin on any of your knuckles when you've finished you've done well
