ABS suddenly OFF
  • s4_rider
    • Apr 2004
    • 44
    ABS suddenly OFF
    If it is a coincidence or not but at 160 km/h my ABS goes off, i.e. the dashboarlight comes on. Tested it on gravel and indeed the ABS is OFF. Are the sensors worn out and/or dirty and cannot follow high traveling speeds anymore ?
    Shutting down the car means resseting this ABS phenomena until you drive 160 again.
    Or was it the hot weather ?
    Regards,
    Ronald
    S4 Rider
  • Sidspud
    • 1223
    • Home: Scotland Current: United Nations
    I've had this. You'll probably find that with time, the speed required to make it switch off gets lower and lower.
    Its a dirty sensor. VAG-COM will tell you which wheel is at fault. Cleaning it should help, although you may end up having to replace it.
    ex '93 Avant owner
    • s4_rider
      • Apr 2004
      • 44
      reason abs suddenly off
      Found it
      keeps you off the street
      S4 Rider
