Can someone tell me if these are Porsche 996 Calipers. I found them on the internet ?
are these 996 brakes
Thats the problem, someone want to sell them on internet. He thought they were from a 996. He had them fitted on his Audi TT.
Can you find the part.nr on the Calipers?.
What is normal to pay for these calipers, if they are from a 996.Getting everything sorted out for my 5++ hp project
another pictureAttached FilesGetting everything sorted out for my 5++ hp project
and the last pictureAttached FilesGetting everything sorted out for my 5++ hp project
They do look exactly like the 996 calipers i have fitted to my car. they have the same pad pin and clip as the newer calipers as opposed to the older 993 style clip, however, why is the seller selling 4 of them? They look to be the same size, don't fit all the same at all four corners...you'll fook you biasJoe "NoNonsense"
axis motorsport
joe@axismotorsport.com
ps...they can be had for about $300 each at a good price...that's roughly 165 GBPJoe "NoNonsense"
axis motorsport
THought about this over night....i cannot say for sure if those are all 996 front or rear calipers...they look to be fronts, but without part numbers, I couldn't tell you for sure. They definitely appear 996, though. Here are the part numbers you should be looking for:
Carrera calipers (black):
Left - 996.351.425.01
Right - 996.351.426.01
Boxster S calipers (red):
Left - 996.351.425.11
Right - 996.351.426.11
Usually, the boxster S calipers cost another 50 GBP each, which is a total rip-off for some red paint. That was just a side note/rant.
Good luck with those calipers!Joe "NoNonsense"
axis motorsport
Thanks Nononsense. I asked the buyer to send me the part numbers.
Is is also possible to fit the calipers of the GT3? and are these the same as the porsche S4 and the Turbo? Is it possible to fit these in 17" Porsche wheels?
thanks,
Erik de BruijnGetting everything sorted out for my 5++ hp project
Erik,
I don't know enough about the GT3 calipers, but they can certainly be made to fit along with a custom set of brackets. The 996 calipers will fit up with RS2 caliper brackets and a 314x30mm rotor (like the A8). Depending on your rotor set-up, though, the 996 calipers can fit a rotor up to 330mm, but rotor coverage wouldn't be the same as using a 322 mm rotor.
PM me if you'd like to chat brakes...i've done a lot of research on 993tt, 996, and 996tt calipers...and i've just started researching on porsche cayanne 6-pot calipers, but it still seems that the 996tt is most efficient.
good luck,
joeJoe "NoNonsense"
axis motorsport
Joe, I consider you the CQ BrakeMeister.
I don't know if I mentioned this but Billzcat1 is putting together a Big Brake kit for me using Boxster calipers and custom brackets and Wilwood hats. He's gonna get them to fit under 16" rims with ET35. I can't wait. They'll be quality cause Billz is a whiz with metal fabbing. Anything you can add to this one-off(for now) will be of value.
Originally posted by panzerwagenI don't know if I mentioned this but Billzcat1 is putting together a Big Brake kit for me using Boxster calipers and custom brackets and Wilwood hats. He's gonna get them to fit under 16" rims with ET35. I can't wait. They'll be quality cause Billz is a whiz with metal fabbing. Anything you can add to this one-off(for now) will be of value.
Billzcat is a metal fabbing master...I wish I could do that stuff because I am trying to design something for my car, but don't have the CNC skills.
What are you going to use for rotor rings?Joe "NoNonsense"
axis motorsport
Originally posted by panzerwagenTo answer your question I don't know. That's something I gotta ask Billzcat.
Ok I'll bite, what's the gray matter in your head planning?
Are those pics of your car I saw online at Treffen 2004??Joe "NoNonsense"
axis motorsport
