i fink its the bomb!!
  • bernsaudi
    • Feb 2007
    • 592
    Hello, ok I now have a brake pedal that would be more suited to a morris marina!! I have had a look as to how to swap the bomb but have not found a post, can anyone point me in the right direction, I have had warning lights for AGES! Ta!
  • Jonnybravo
    • Aug 2008
    • 2051
    I never found them all that hard to remove. Possibly easier to get access from the underside and I expect anytime I have done one the rad was already removed.
    Do you need a brake bomb ?
    • bernsaudi
      • Feb 2007
      • 592
      I have one that I will dig out, however I read there are different ones so possibly yes....is it a couple of hours job?
      • Jonnybravo
        • Aug 2008
        • 2051
        I would say a couple of hours is more than enough time to change one.
        • bernsaudi
          • Feb 2007
          • 592
          Right, i'm home for a change...I'm gonna have a go after dinner, hope the one i've got is the same as the one I want to change it with
          • jimmcf
            • Jan 2011
            • 105
            dont forget to de pressurise it first, mind you if its that shot then it won't take many pumps of the peadl
              out of interest, does a dead bomb mean you have reduced assistance? My bomb is well shot but i've cured the symptoms by unplugging the servo pressure sensor
              My breaks are really wooden with minimal bits, but they do really stop the car, just requires you to push the pedal HARD
              Running 996s with textars (yes i know.. )
              • Mikes2
                • 1704
                It's the servo that provides the brake assistance.
                The bomb is to provide emergency brake assistance in the event of engine failure
                Mike
                http://www.s2-audi.co.uk
                  yup, thats what I thought I have replaced a couple of servos on these cars before. BUT I have read a few people comment that the brakes felt more responsive after fitting a new bomb - maybe becasue on a discharged bomb some of your pedal effort goes toward compressing the diaphragm and the little remaining gas in the bomb?
                  • bernsaudi
                    • Feb 2007
                    • 592
                    I got as far as cleaning up the spare before falling asleep! So the word here is that its the servo that is bust? The pedal is hard and emergency stop is rubbish, it's on big reds and that is the saving grace at the moment I think!
                    Been a busy week, and my other half is using the car all the time so I am in need of spending some time on my poor old wagon.
                    To be honest I didnt think it had a servo on! oops.
                      I'm not convinced, I have replaced faulty servos before and mine doesn't feel like the servo.
                      In my logic, a new bomb is putting 200 bar or whatever pressure it holds against the brake assistance circuit so will mean less pedal effort required.
                      • bernsaudi
                        • Feb 2007
                        • 592
                        I feel a bit daft cuz i didnt even notice a servo(after having the car for 4 years!), I always thought the power steering pump did the hydraulics for the brakes(its a 94 aby by the way). So you are inclined to the bomb then? Cars not back till sunday now so I'm in the dark till it gets back
                          In my experience when the servo goes the brake pedal is soft as butter and/or goes to the floor, with very little stopping power being generated. You can also often also feel the pump pulsing through the pedal.
                          • bernsaudi
                            • Feb 2007
                            • 592
                            Ah! That is not my situation at all, the pedal is firm with very little top play on it. Push on it and there is half inch to an inch before it bites, no pedal fade or drop, just wooden and not fierce.
                              same as mine. I'm sure its the bomb
