I have the eBay grooved discs and yellowstuff pads good setup so far. I also put new calipers on. I think the main cause of warped discs are down to calipers not operating smooth. The reason I changed mine.
Slotted / Grooved Brake Discs 314mm 323mm
You sure you're getting the grooved discs? If you are, that's silly cheap for the quality if what you get. Mine have bedded in nicely and other than the monoblock noises, they're sweet. The black coating should stop corrosion on the hub too
Yellowstuff pads are surprisingly good nowadays too, I run them on my Clio.and for the cash, they're great.Cheers'en, AndyC
Yellowstuff not cheap for the hp2 caliper £150 was the cheapest I could find. 4 pads per caliper. Discs are good quality vs price under a £100 delivered. Can't complain......
My problem is the company I bought new calipers sent me one correct caliper and the other was for the 321x30 disc. So has pad overhang. I need to find another caliper hence the signature. Most of the caliper is the same apart from the mounting holes being slightly different.
Company cant supply the proper caliper as they can't find the match for the other side. It took them a month to send the right side. Leading/ trailing........
So running with a new caliper on drivers side and old on the passenger side. Not ideal but still work good.Last edited by K7ERG; 6 June 2012, 10:37.Audi A6 AEL 5cyl Quattro breaking.
Audi A5 3.0tdi Quattro Stage 2
07947385043
I asked for 8 grooves and the black coating. Let's hope they get it right.
I've currently got trextar pads in the 993 calipers so hopefully they'll bed in nicely
Sent from my HTC Desire using Tapatalk 21996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
My trextars will no doubt be shot after my nurburg/alps trip in august
Haha it might even make these alloys look better!
Some brake cleaner is an.essential item to take I think....
Camskill just confirmed they were ordered with 8 grooves and black coating, so hopefully its just the Bargin of the day!
Got them through and all is correct! Don't.know how they're now £45 cheaper. Look great and brilliant service!
