Originally posted by AndyP
View Post
Vacuum Brake Servo
There is an A/C pipe runs in that area to the drier in the right hand wheel arch. If the servo is going to foul anything it WILL be that.sigpic
BUT I DON'T WANT A NEW CAR!
1995 S2 Avant, Volcano Black
Originally posted by AndyP View PostJust found this pic in his build thread, looks tight!
ABY S2 stroker (work in progress)
B5 1.8T quattro
B4 2.3 (decommissioned)
Originally posted by Pat D View PostIs this an earlier S2? I just had a look at the size of my vacuum servo on the B4 and it looks like it won't fit as my S2 has braces welded from the strut tower to the firewall on my S2 which are right in the way of where the servo will sitsigpic
I have few questions in regards to the brake bomb and high pressure lines, hopefully someone might know the answers.
1. Is the high pressure line from the PAS pump to the steering rack a different pressure to the one going to the bomb? Hence two separate pump outputs?
2. Can the bomb be deleted all together if there is no need for assist in the event of the engine not running and just run the high pressure line direct to the master cylinder?
Reason I ask is that I would like to use an electric PAS pump without Vacuum servo brake assist, since the electric pump can run with the engine off there is no need for accumulated assist.ABY S2 stroker (work in progress)
B5 1.8T quattro
Hey Pat:
An electric PAS pump won't offer you brake assist aswell. You would still need to retain the dual stage PAS pump, making the electric PAS pump kinda pointless. That is why people switch to electric PAS pump and vacuum servo at the same time. Or just vacuum servo and use a single stage hydro PAS pump as per the factory setup
The bomb works off the front section of the dual pump, using pistons driven by an elliptical collar, which AFAIK is higher pressure but I assume much lower flow than the steering side (the brake assist consumes very little fluid by volume compared to the rack)
The steering circuit is about [100bar].
As well as an accumulator, the bomb acts as a pressure damper for the servo, without the bomb i think you would need to use something to smooth the pump output, otherwise you will feel the pump through the brake pedal and it wont be very pleasant (feels like the ABS is on continually)
So I would just cut that strut bracket and make your life easier
HTH & Merry ChristmasPanthero Coupé quattro 20vt
Originally posted by Pat D View PostI have few questions in regards to the brake bomb and high pressure lines, hopefully someone might know the answers.
No, you cant run the pump line straight to the servo, a couple of quick taps of the brake and you would have less pressure as the pump is not be able to keep up, that's why you have an accumulator, it's not just in case the engine stalls or the belt snaps.
You will find that even cars that use electric pumps have an accumulator, usually as part of the pump assembly, I looked at fitting one once, I think it was off a jag.
I'm wondering how much support that strut bracket provides and if it's worth fabricating another one around the vacuum servo.ABY S2 stroker (work in progress)
B5 1.8T quattro
Originally posted by driftin jo View PostABY S2 stroker (work in progress)
B5 1.8T quattro
Originally posted by Pat D View PostHaha, that's what i was trying to avoid
I'm wondering how much support that strut bracket provides and if it's worth fabricating another one around the vacuum servo.Panthero Coupé quattro 20vt
Originally posted by Pat D View PostI'm wondering how much support that strut bracket provides and if it's worth fabricating another one around the vacuum servo.
Edit : You can see it in this post here, LHD, but you get the idea.
http://www.s2forum.com/forum/showpos...&postcount=482Last edited by AndyP; 24 December 2012, 12:05.sigpic
Great, well I'll stick with the original plan and use an electric PAS pump and vacuum brakes. I'll cut the strut bracket out tomorrow.
I just removed the vacuum servo from my B4 and emptied out a good half litre of brake fluid, so I filled it up with degreaser and then hosed it out. Should hopefully still be ok.ABY S2 stroker (work in progress)
B5 1.8T quattro
