Brake disc skimming???
  • stevieyid
    • Apr 2005
    • 2251
    I need to get some brake discs skimmed but not sure where to get them done in the south east London areas? Also what sort of cost should I be looking at?
    last time I looked it was more expensive than a new set of rotors at circa £60 a corner, but I suppose it depends on how expensive the rotors are to begin with.
    You need to have them reground really as they get so hard from all the heat cycling that cutting tools tend to just chatter across the surface.
    • s2_wot
      • Aug 2006
      • 2178
      Originally posted by icelightblue1:285411
      Hi Guy's
      I have been given a machine as part of a debt owed and have sold it on and put it at a friends garage.
      Awesome bit of kit, can do up to 400MM Disc's
      911 SBD Ltd
      Unit 5 ,
      Wellington Park Estate,
      Waterloo Road,
      London,
      NW2 7JW
      If any members need their brakes disc's rejuvenated I have organised a 30% discount to SRS members at the 9911SBD garage. Just mention AudiSRS to them
      Kind regards
      Bim
      No connection to me I just copied from this thread: http://audisrs.com/about22985.html
      Shane
      • QuattroFever
        • May 2006
        • 1360
        bensham engineering in west croydon is good.
        I have my machine work done there.
        Volcano ABY coupe
        Ant
