On with my ongoing issues with my brakes, and after already having spent about 2000euros in parts, i was wondering if anyone could add to the issue, or have had something like this related as well.
Story goes:
2004---> first bought the car, and without having any experience with steering fluid, i mistakenly used the red stuff. immediately my steering went bad, and i drained as much as i could out, but eventually after a year or so, had to replace the steering pump. After that, everything was fine until...
03/2010, after a brake disc/pads change, bomb accumulator and brake fluid, i leave from Greece to head back to the UK. I was a bit suspicious about the type of brake fluid inserted until i realised that indeed it was a fluke. After 2-3 months i replaced the brake fluid due to a spongy feeling of the brake pedal, used proper 5.1 from opie oils and also thanks to Paul from autocrafts Berlin, replaced the brake bomb as we thought at the time that this may have also had an issue.
7-8/2010: Indeed bomb was sent back to Paul, and was examined to be able to hold a below standard pressure. New bomb improved things to a good extent. Then the hose going from the bomb to the servo was leaking and i ordered the new one, which Audi replaced with a BRAIDED one rather than the rubber one, although i did order one from the Audi Tradition shop. Ended up having 2 replacement hoses(they were cheap anyway) but used the braided one. Leak was fixed, and brake was still feeling spongy...
sometime end 2010/beg 2011: after discussion with GT500, i buy a new servo from germany, from a shop that tells me that they had it from Audi dealers. A new servo and master cylinder arrives and looks brand new. Rob fits it, brakes are rebled for the milionth time, and brakes feel absolutely perfect! Like butter and good responce!
Thinking that this is the end of it, we leave it at that.....
....But, i could still only lose all pressure on an off engine after 5-10 pedal presses! What the hell? All hoses are fine, no leaks, bomb new, servo new, and it's still doing it??
Another call to Paul for yet another brake bomb, to which i must say that Paul has been a great guy supporting me through this sending me replacement bombs under warranty! So i have this one, which has been the 3d bomb to try out.
At the same time, i decided to give my calipers a refurb as well as change the 2 rear hoses so that we dont have any problems with the pads or calipers relating to these problems. Fit everything up, new bomb, and here is the problem now:
On OFF engine, i still loose pressure after about 5-10 presses.
On ON engine, idling: if i press the pedal 4-5 times all the way, i loose pressure and the pedal goes down juddering!!!!
If i leave it, the pressure builds up again and i have brakes that work.!
SO to make sure that this is not a steering pump problem, i have the pump replaced as well on my local garage as well as the sensor on the servo which seemed to be leaking a bit. So now the problem persists, and when i reach the juddering issue, i get the brake warning light as previously my sensor was faulty!
So to summarise:
Bomb: NEW
Servo: NEW
Sterring pump: NEW
Master Cylinder: This has been kept the same because according to Rob, it is absolutely fine and does not show any signs of wear.
Hose from steering pump to bomb---> was replaced with a new item from VAGPARTS(was leaking early on)
Hose from servo to bomb: new braided hose from audi
Here are the speculations:
1) could the braided hose be partially blocked and therefore not allowing the steering fluid to flow from the bomb to the servo adequatelly? ----> will change the hose to the rubber one i have got from audi to check.
2) Could the servo itself, although new be faulty??? ----> the german shop asked to send it back so they could get a replacement one from audi (hopefully)
3) Could this be a bad batch of bombs/wrong bomb? ----> i find it hard to believe as the bombs i bought from Paul were identical to the original one that was on the car, the car is dated 1995, and i believe the bomb i have is the one building up higher pressure than the rounded one.
Solutions:
? fit an S2/audi 80 V6 servo, (shorter) bought used with a different bomb to servo configuration to see if the problem goes away, and then send the servo back to germany to have it replaced with a similar unit
? Delete the hydraulic servo and bomb all together and use a drum servo. For this we would need a vaccum from the inlet manifold and a good one way valve to make it work. Anyone done this before? Also we would need to blank the parts of the system that work with the hydraulic system.
? Fit another master cylinder 'just in case' to rule out any misnehaving of the current one due to the bad brake fluid?---> but the problem here seems to be with the hydraulic pumping to build the pressure in the system, not the bit that involves the brake fluid bit..
As you can see, this is an issue that has been not only costly but frustrating, as besides are best efforts to make it work, it is on going.... I would appreciate any comments/help available!
thanks
Vas
Story goes:
So to summarise:
Bomb: NEW
Servo: NEW
Sterring pump: NEW
Solutions:
thanks
Vas
