ABS fault
  • gers1
    • Jun 2010
    • 55
    ABS fault
    Could low brake pressure - (!) warning sign flashing on start up - cause ABS pump not to function properly? Or could I just have two seperate problems? Faulty ABS pump and brake servo issue?
    cheers
    Jonathan
  • Phil Payne
    • Jul 2009
    • 328
    cheers
    Jonathan
    ABS pump failures are rare. Check battery voltage and the combinaion relay (with the fuse on top) - is pin 87 OK?
