RS2 disc dimension diagram
  • Boghopper
    • Aug 2010
    • 136
    I have been looking for 2 hours now and I give up!
    Has anyone got a diagram and / or measurements for the 322mm RS2 front disc?
    Thanks
    Pete
    Audi RS2 Volcano Black, MRC chip, Milltek exhaust
  • jade
    • Jan 2005
    • 1811
    Thanks
    Pete
    There was a daigram of the bells posted a long time ago, but I could never find it again
    I posted the same request 2 months back but had no response
    I have some 40mm bells if that any help they can be used as a patten to make 45mm bells I was looking also for these
    W
    RS 2 580HP
    • Boghopper
      • Aug 2010
      • 136
      Bump
      I have tried the search for some time and any help locating the correct posts would be much appreciated.
      I have found a diagram for the rear discs and could do with one for the fronts.
      The hat height for the fronts is 45mm, yes?
      Where is it measured from/to please?
      Pete
      • jade
        • Jan 2005
        • 1811
        Bump
        Pete
        45mm from wheel mounting face to disk, 77mm overall to back face
        RS 2 580HP
        • Val
          • Apr 2008
          • 630
          • Country: Latvia
          5vtq gte
          • Boghopper
            • Aug 2010
            • 136
            Thanks for the info and links.
            Could anyone tell the thickness of the disc at the hub face, ie, how far the disc spaces the wheel off the hub.
            Pete
