Just developed a ABS problem - its staying on all the time! It doesnt seem to matter if I switch the ABS on or off (its a 3B). I can hear the ABS pumping away and feel it through the pedal
Started immediately after I started up this afternoon (fine on the drive before I parked the car up!) The ABS light came on and the car felt a bit juddery (I actually thought I'd left hand brake on!)
ABS light has stayed off since and the light comes on with the switch - but the ABS is staying on!
Any thoughts? Cheers!
) but Ive pulled the two relays on top of the ABS pump. There's still a vibation though the pedal when I push down - tho I cant seem to hear the ABS clicking away as it did earlier.
This is with the car idling tho and not being driven.
Means I can get on changing the pads on the wife's Beetle
Definite possibility, something similar happend to my old VR6 Corrado.
