Iv recently got my S2 on the road having purchased needing some work doing. Its been running fine until the last couple of days where the ((!)) red dash light comes on after starting up then waiting about 10 seconds after its finished its usual diagnostics which end in OK. Iv so far checked;
Pads and discs which all look to have loads left being almost new.
Rubber hoses that arent cracked bulging or leaking.
All the metal brake lines i can see all look spotless.
The power steering and brake fluid levels are all just under max mark and not moved, although not sure how I would test if these have degraded due to age?
Any joints of pipework to cylinders, to abs unit that i can see and none are damp.
Stopping heavily seems to work fine and the peddle doesnt feel spoungy or move excessively, infact the smallest travel on the top end of the peddle is enough to slow down and pressing half way through its movement will stop the car quite heavily.
Turned the engine off and did the "bomb test" and got 54 pumps before it stiffened which seems promising.
It does sometimes make a slight squeel from both front wheels like the brakes are dragging while i drive, but if i stop and press the brake as hard as i can then carry on driving this seems to go away for a while no idea if this is coincidental.
After driving the font wheels were quite hot last time, cool enough to touch but still hot, the pads behind were too hot to touch and i hadnt been driving particularly heavily at this point.
There wasnt any noticable brake fade pulling up to stop and there wasnt the usual burnt brake dust smell of dragging brakes that i would expect for this though.
Anyone have any ideas what to try next or what it could be.
Thanks.
Thanks.
