ABS ring is part of the CV joint. But it is pretty robust. Are you sure you need a new one? They do get a little rusty or dirty sometimes, but usually clean up ok.
one of the rear rings on my last aby totally rotted away(like a lot of the car tbh).Rings are available(non oe) but by the time you have pissed around you may aswell stick a new one on ime
I changed a trigger ring a few years ago. It was a newish one on an old joint in the scrap yard, so I carefully eased it off and equally carefully eased it back on mine. My old one had rotted off too.
