Brake Lines For 996 Upgrade - *URGENT*
  • steverrquattro
    • Oct 2006
    • 787
    Hi All,
    I urgently need a set of front brake lines for mr UR Quattro. I'm upgrading to the Porche 996's. The problem is that the Company that has been recommended don't seem to be answering the phone, the voice mail box is full and no reply to e-mails.
    My main issue is that I am going on the Tour De Ecosse next Thursday and can not go in the car as it is due to a combination of brake set-up and wheel size. Basically when you brake and turn, the wheels push the wings out!!!
    Any recommendations please.
    Either PM or text to 07889 317827
    Thanks in advance.
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
  • robo
    • Aug 2004
    • 2086
    Steve where did you get the brackets from?
    I have used rs2 brake lines for may s2 and SQ.
    Originally posted by steverrquattro
    Hi All,
    Thanks in advance.
    sigpic_________
    Rob
    • Rusty
      • 18953
      RS2 lines can be made from copper brake pipe... as that's all they are
      My 996s are M10x1 and just use the OE lines to get the other end correct where it joins the flexi.
        make a small 90deg bend in copper line and use your OE flexi lines.
        • djh
          • Jun 2011
          • 1622
          what wheels are you using?
          • TDi90
            • Nov 2009
            • 272
            I have a set of brand new RS2 lines which i was going to use to convert mine to 996's. you can have them for what i paid for them plus postage. PM me if interested.
            • URquattroGus
              • Aug 2007
              • 547
              Mine were done like this too, works a treat! Allready had goodridge hoses.
              Angus
              (1984 ur quattro)
              • TimE-J
                • Jul 2009
                • 1292
                I'm the same they took all of 10 minutes to make.
                96 S2 aby Coupe. Rebuild Project
                96 mk3 golf tdi daily.
                • steverrquattro
                  • Oct 2006
                  • 787
                  Any pics. of this or rough dimensions?
                  Steve
                  1990 RR 20V
                  • URquattroGus
                    • Aug 2007
                    • 547
                    This is what min look like, but did not make it myself.
                    Angus
                    (1984 ur quattro)
                    • BRY
                      • 3755
                      I hope that picture is upside down, otherwise, how do you bleed them?
                      • driftin jo
                        • Sep 2007
                        • 2222
                        I hope where that hard line joins the flexi that the flexi is held fixed in place by something, if not then the hard line could be moving slightly when you go from lock to lock and this could work harden it and it will snap off !
                        • URquattroGus
                          • Aug 2007
                          • 547
                          I can't see the pic as it won't load at work. Probably pic is upside down and I think there is a clamp for the flexi.
                          Any more holes people want to pick without having seen the car!?
                          Angus
                          (1984 ur quattro)
                          • BRY
                            • 3755
                            Just keeping you as safe as we can
                            • driftin jo
                              • Sep 2007
                              • 2222
                              I'm not saying there isn't a clamp just that from the pic it there does not seem to be one.
                              I'm only trying to help, if there is no clamp for the flexi then me pointing this out
                              could prevent you from ending up dead when your brake line snaps off.
                              You don't have to take my advice or take offence,these choices are yours.
