Hi guys,
What do you suggest for rear brakes upgrade? Issue is what kind of caliper I can use and keep my handbrake cable carriers are not an issue. I'm after for minimum 280mm ventilated disk like S8 rear calipers, but maybe you can suggest something a bit bigger than that?
I saw somewhere that Girling 41/43 is able to go with 304 or 314mm disc ? If this is true from what car this calipers are?
