Will the calipers from an Rs4 b5 fit the s2 also a silly question i think would the rear cals from a 997 porsche fit the front of the s2?
Rs4 calipers
Do not use RS4 B5 brakes, use RS4 B7 ones.
A set of discs costs over 1k at the dealer for the B5.
For the rear you can use the brake setup from Audi S3 2.0 TFSI (also on other 2.0 TFSI cars), where you can get discs for 30 quid and pads for 20.
The B5 RS4 has special discs. Almost no aftermarket options and really expensive, what's worse, they are just big lightened discs with an odd shape, no real advantage other than size. I would look at a cheaper, newer and better alternative (B7 RS4 front, S3 2.0TFSI rear for example).
if you want i have for sale a very nice and healthy RS4 B7 brake sistem...8 piston calipers with 364x34 floating discs with alu bells
plug/play in our S2 front hubsRED Mitsubishi Lancer Evolution VI TME nº 16 of 250
