ABYcoupe 996 turbo front brake upgrade
  • Audi500HP
    • Apr 2004
    • 85
    • Country: Chile
    Hi there
    Im planning to install a S8 discs and 996turbo front calipers, I just want to know if Ill be able to use my original Avus 7.5 x 16 inch wheels... Do i need to buy spacers? or new 17 inch wheels?
    please some advice
    thanks
    Fernando
    Audi S2 94 6 speed ABY-ADU 330hp, Lancia delta EVO2 mint
    Dr.Ferdinand
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    Originally posted by Audi500HP
    Hi there
    please some advice
    thanks
    Fernando
    HI Fernando,please forget it and buy my S8 mk2 wheels with almost new rubbers + my current rs4 b7 8 pot brakes with everything needed and 365 x34 floating discs.
    • Colesy
      • Feb 2009
      • 2980
      Hi there
      please some advice
      thanks
      Fernando
      It depends on the brackets & discs you use, the 323mm A8 setup requires 17" wheels but the smaller 318mm discs and appropriate brackets fit under the 16" Avus. Bambridge on here sells the brackets.
      • will20v
        • May 2007
        • 391
        i have a set of brackets for 323mm discs with 996351429 and 430 big red calipers monblocks pm me if you need them
        will
        • Audi500HP
          • Apr 2004
          • 85
          • Country: Chile
          seems that Ill need 17 inch rubbers
          I already bought the discs and calipers with the adapter... Im planning to install them in the next 2 weeks. So Im asking to avoid surprises. I have 5 new 17 inch ultraleggeras waiting to be used, but I dont have more money for rubbers... so I was trying to extend the use of my 16 inch avus for a while.
          Thanks
          Fernando
          Dr.Ferdinand
          • robo
            • Aug 2004
            • 2086
            Hi there
            please some advice
            thanks
            Fernando
            If you use 996+rs2 bracket 16inch wheels will meet calipers at some point at heavy braking as I found out, but if you use 10-15mm spacer they will be ok.
            sigpic_________
            Rob
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              Thanks
              Fernando
              or sell the new wheels, your caliperr and rotors and buy mines
              easy
              good luck¡¡
              • will20v
                • May 2007
                • 391
                You Cant Use Rs2 Brackets With Big Red As The Radial Mount Is Different Between The Holes .
                Rs2 Bracket 130mm Ish
                Big Red From Gt3 Or Turbo Cars Are 143mm Ish
                If You Have 425/426 Monoblocks Then You Can Use The Rs2 Bracket
                • andy10v
                  • 5996
                  what size discs/brackets have you got?
                  I have 996/a8 314mm discs and bambridge 314 brackets, they fit under my ABY s2 16" wheels (very close), but not the 3b 16" wheels (apparently fits with spacers).
                  I understand the 323 will not fit under 16s
                  Sold ABY-stock
                  • will20v
                    • May 2007
                    • 391
                    323mm s8 discs go under 16inch 6 spoke avus aby wheels with 10mm spacers with 425/426 monoblocks but not with the 429/430 mono big reds
                    • Audi500HP
                      • Apr 2004
                      • 85
                      • Country: Chile
                      Damn, I have the 429/430 Big reds from a GT3 with 323mm S8 disc... so no way to use the ABY AVUS 16 inch wheels?
                      thanks
                      Fernando
                      Dr.Ferdinand
                      • Le S2 Audi
                        • Jul 2009
                        • 3805
                        thanks
                        Fernando
                        No they wont fit!! You will need your 17" but that might even be a squeeze!!
                        You may need spacers but you will have to fit them to find out!
                        New S2 - S8 & RS2 -RS6 Keyrings
                          No chance, 17" rims mininimum
                          On the RS2 hubs they fit with 330mm discs no problems with 17" alloys
                          On S2 hubs will be the same just different PCD and hat height of discs
