part number for 323mm A8 discs?
  • HORCH
    • 330
    can someone help me with these please? I have searched loads of pages but cant find my answer, sorry if its been asked loads of times
    I've put in abay audi a8 discs and found a few different diameters and hat sizes etc so I'm confused now,
    I've got some 996 calipers and going to get some brackets for them from bambridge which use the 323 size discs
    will the part number be the same for brembo ones aswell? I'll also need pads so part numbers for pads would be good aswell
    thanks for any help
  • mcandmar
    • Apr 2004
    • 5118
    Cant help with specific part numbers but when i bought a set i ordered them for a 2000/2002 age Audi A8 with 323mm disks. Bolted up perfectly to 996's with Bambridge brackets. From memory the later A8's had a smaller hat height.
    For pads just order a set for a basic Porsche 911 C2 (2wd 996 , 1998-04). I'm using the Ferodo DS2500's on mine.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • simon20vq
      • Dec 2010
      • 1379
      Just bought these myself and the details of the disc size are, Disc measurements:- 323mm diameter, 30mm thickness, 60mm overall height, 68mm bore, 5 + 5 stud
      • HORCH
        • 330
        thanks for the help lads, I appreciate it
        • sjw185
          • 1175
          I just got new 323 discs part number disc 4D0615301J
          And daily driver pad Lockheed Delphi pad LP1996
          cheers
          steve
          • Condor
            • Jul 2004
            • 424
            Hi All. I too have 996 caliper conversion on my 1991 S2 Coupe.. I need new front discs.. are these the correct ones to buy? Thanks ....
            Brake Adjuster Kits Brake Discs Brake Drums Brake Pad Fitting Kits Brake Pad Set - Parking Brake Brake Pads. Bleed Valves Brake Caliper Accessory Kits Brake Hose Kits Brake Hoses Brake Pressure Switch Brake Master Cylinder Parts Brake Master Cylinders. | eBay!
            :wave: :thumbs:
            • Condor
              • Jul 2004
              • 424
              cheers
              steve
              Hi Steve, how do/did you like the Delphi pads? good performance? wear out quickly or? thanks Condor..
              :wave: :thumbs:
