Solid Brake Lines
  • willg54
    • Jun 2009
    • 2055
    Solid Brake Lines
    Has any body ever made their own solid brake lines?
    An 'event' has caused the need for me to put atleast 1 new rear brake line section in.
    I'm thinking a wade connector to connect it up to the old line but the other end im not too sure.
    From what i can tell they use a bubble fare to the end of the solid line but what unions are used?
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Ebay item nr. i used at mine.
    290572256462 2 pcs for each brake pipe
    150313903763
    190618987164
    Goodluck!
    • driftin jo
      • Sep 2007
      • 2222
      Yes they are a bubble flare, they use a 10mm x 1mm pitch male back nut 15mm long.
      • willg54
        • Jun 2009
        • 2055
        top stuff! Should be sorted in no time, and have shiny new lines!!
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Take care that...i used the 10mm long threaded pieces...not 15mm.
          They worked....but ...indeed...will be better to use the 15mm ones.
            don't use a wade connector or you will crash and die screaming like a pig in a war (probably)
            to join the lines together, use a female-female thread coupling, with male unions on either end of the pipe to be joined, with a flare as per the flexi line end
            • driftin jo
              • Sep 2007
              • 2222
              Yes I agree, you don't need to join anyway as IIRC the rear lines go into a T piece so you just make a new line from this to the wheel arch .
                yup there is a 3-way female union around the battery box area
                Just out of shot in this pic:
                • willg54
                  • Jun 2009
                  • 2055
                  even better! thanks for the advice guys. this forum is amazing!!
                  hopefully rolling her out the garage tomorrow to make some noise! Then transport down to exhaust fabbers to get a full 3" system on! Then i'll sort the brakes!
                  • driftin jo
                    • Sep 2007
                    • 2222
                    How long is the one you need, I have one here I made up for the front, I made both up as the drivers side one nut had rounded off, the passenger side one was OK so I didn't replace it.
                    It is 750mm if it is any use you can have it for postage cost, it's cupro nickel not **** copper also.
                    • willg54
                      • Jun 2009
                      • 2055
                      I'll measure if up in the morning but that sounds about right.
                      I think i might end up doing them all though, can't have 1 shiny line on there
                      Should have seen that joint earlier...was mounting the fuel filter up!
                      • willg54
                        • Jun 2009
                        • 2055
                        Anybody know where to buy the M10x1 15mm unions from? Closest I have found is 17.24mm....
                        • driftin jo
                          • Sep 2007
                          • 2222
                          A bit longer won't matter, you just don't want them too short as they may bottom out before they clamp the seal tight.
                          • willg54
                            • Jun 2009
                            • 2055
                            sweet. thought that was the case but worth checking! Cheers
                            • willg54
                              • Jun 2009
                              • 2055
                              for future reference...
                              I've ordered THESE fittings M10x1 Short-type (17.54mm according to Automec website)
