Possible new large brake disc option
    While I have been working on the rebuild on my S2 a Volvo XC90 came through the garage and had new discs fitted which gave me an idea.
    I currently have the AP racing setup with 330 x 32mm discs. From a quick search on the web the hat height on the S2 is 56mm and the XC90 is 52mm with 5 x 108mm bolt spacing.
    With a 4mm spacer and a small amount of machining to extend the bolt slots it could be possible to use these on mine when the AP discs need replacing at a considerably lower cost.
    Standard XC90 discs are about £80 and EBC grooved £140. Replacement AP's ~£300 and some on the bay for £90 http://www.ebay.co.uk/itm/VOLVO-XC90...16099742083590
    Once I have the engine sorted I will revisit this properly. But thought it might be useful if anyone else wants to investigate it in the mean time.
    Also on the earlier XC90 models they had a 316mm x 30mm disc
    • europeanme
      • Oct 2005
      • 3817
      Q7's are 350mm...and they are about the same price!!...just need the PCD changing...
        Thats cool, only thing is my setup is for 330mm discs instead, depends how much could be taken off the Q7 discs
        • europeanme
          • Oct 2005
          • 3817
          10mm a side should be fine...
          I'll let you know how I get on finding the details....
