porsche 944 brakes
  • aronmatic2
    • 2129
    • Country: Hungary
    porsche 944 brakes
    who knows anything about this brakes:
    porsche 944 1987
    porsche 911 carrera,c2 1993
    can i install to my s2? is this good choice?
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
  • 20Volt
    • 36
    porsche 944 1987
    Just arrived my A8/S6 brakes, I'll fit it next week. You can try that those brakes are enough for you, or you want better.
    Porsche brakes: The brake console for RS2 part nubmer is 8A0 615 125 A. I think that useable in fitting the brakes. I'm afraid that it can only ordered together with the whole brake stuff... or use a chunk of steel and some machine work.
    2.2 20Volt Turbo fan from Hungary
    • Stick Insect
      • Dec 2003
      • 2338
      porsche 944 1987
      the 911 calipers should be ok. use RS2 mounting brackets or Seat Cupra RS mounting brackets( same size and shape). you can then use a 324mm Audi A8 disk turned down to 304MM. HTH
      Have a look in the brake forum.
      David
