I thought this was only done to add clearance on the 425/426 setup for the 30mm dics as they are supposed to run 28mm discs on the Porsche?
Depending on what size discs you are running it should not be essential
You would think so but I had to to clear 330x32 as said clear to fit the setup on your car, I was told I wouldn't but we had to in the end as it was too close
